24-bit monitor and grass
Nalneesh Gaur writes:
We have a IBM RISC6000 and a 24 bit monitor. We installed GRASS normally
on it and it works.
Someone would have to prove to me that you are actually running in 24
bit mode (or someone has altered the GRASS code). The way X handles
24 bit vs. 8 bit is so different that there is no way (that I know of)
that code written for 8 bit systems will actually display all of the
avialable colors of a 24 bit system. Most 24 bit systems can be run
in 8 bit mode - but then you lose the greater color capability.
Pat McClanahan Internet:mcclanah@dlgeo.cr.usgs.gov
EROS Data Center mcclanah@edcserver1.cr.usgs.gov
Sioux Falls, SD
605-361-4607
