We recently tried to run GRASS on a ShoGraphics X-terminal, model PS1. This
is a 24 bit color device. We received the following error message when
the d.mon command was executed:
Graphics driver [x0] started
Please start graphics monitor <x0>.
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 78 (X_CreateColormap)
Minor opcode of failed request: 0
Resource id in failed request: 0x27
Serial number of failed request: 225
Current serial number in output stream: 226
Error - Graphics monitor <x0> not running!
Problem selecting x0. Will try once more
Any ideas?
C O N T R O L | Control Data Systems, Inc. |
___ ___ | Donald R. Baird baird@dsr.cpg.cdc.com |
/ __| __ \ | St. Louis, MO 314-872-2237 |
( (__ __) ) | FAX - 314-872-2206 |
\___ |___/ +- - - - - - - - - - - - - - - - - - - - - - - - -+
| "It's much easier to apologize than get per- |
D A T A | mission." - Adml. Grace Hopper |
