| I tried to download the progman3.0 manual and print it but only
|got the first 14 pages of what appears to be two hundred or so from the index.
|I wonder if the original copy on the ftp server is corrupted as the file
|is approx 600k which seems rather small for hundreds of pages of postscript.
The file containing the 3.0 programmers manual which is available
ftp is doc/3.0.progman/progman3.0.cpio.Z. This is a compressed
cpio file (about 600K). You need to uncompress the file and then
run
cpio -odc < progman3.0.cpio
To extract the postscript version of the manual. If you do this
you will get 3 files with the following sizes:
2868483 doc.ps
9776 figures.ps
65033 index.ps
You must have cpio on your system. If you don't have uncompress,
then just get progman3.0.cpio instead of progman3.0.cpio.Z and
out ftp server will uncompress the file as it transfers it to
you. And make sure yo have binary mode set before you get the
file.
Of course if you did all this then the problem really does lie
with what is on the ftp site.
