4.1 compile failure:
I had one other rather strange event I haven't tracked down yet. I used
setup in a normal fashion, but it failed to place the -I flag for the
compiler as a prefix for $XMINCPATH, the Motif include path. This brought
the XGRASS compilation to a halt. I manually edited the file CMD/head/sun4
to patch the Gmakefile problem, but I haven't had time to explore the setup
script yet to figure out what happened.
Anyone have a similar event?
  Yep, same happened to me (on HP UX 8.05, gcc 2.3.3)
  There are also one or two problems with other xgrass modules:
  in src/xgrass/libes/Xgi/Interact.c, line 491, our X release
  didn't know about XtInheritFocusMovedProc, changing from
  Xt to Xm made it compile (haven't run it yet). Is that specific
  to HP (Motif 1.1)?
  Also, when trying to link xgrass4.1.exe, I get the unsatisfied
  symbol _XtGetCallbackList. This is declared as an external function
  and used in src/xgrass/libes/Xgi/Help.c (lines 1033 & 1041 resp.).
  It is defined on our Suns and even SCO UNIX knows about it, but
  HP (grumble...). Any ideas what to do? Is it really necessary?
  Martin
Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
Kiel University, Olshausenstr. 40, 2300 Kiel, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma@informatik.uni-kiel.dbp.de
I have the same problem with _XtGetCallbackList in libes/Xgi/Help.c
This is the point where I stopped to compile 4.1beta because I didn't know
how to continue. I would be very glad for hints how I can get around this
problem !!!! PLEASE HELP !!!
I am compiling on a Apollo Domain machine that are the same as HP nowadays.
Lars
Lars Schylberg Email: larss@fmi.kth.se
Dept. of Geodesy and Photogrammetry
Royal Institute of Technology (KTH) Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
Here is the error log:
cc -o //blyger/usr/grass4.1/etc/xgrass4.1.exe -s OBJ/main.o OBJ/callbacks.o OBJ/client.o OBJ/create.o OBJ/error.o OBJ/exec.o OBJ/exit.o OBJ/history.o OBJ/link.o OBJ/xgdbset.o OBJ/parse.o OBJ/grammar.o OBJ/lex.o OBJ/strdup.o OBJ/xc.main.o OBJ/xc.grammar.o OBJ/xc.lex.o OBJ/xc.error.o OBJ/xc.parse.o OBJ/xc.client.o OBJ/xc.modify.o OBJ/xc.verify.o OBJ/xc.name.o OBJ/xc.assign.o OBJ/xc.exit.o OBJ/xc.comstr.o OBJ/xc.require.o OBJ/xc.create.o //blyger/usr/grass4.1/src/xgrass/libes/LIB/libXgi.a //blyger/usr/grass4.1/src/xgrass/libes/LIB/libXgd.a //blyger/usr/grass4.1/src/libes/LIB/libgis.a -L/usr/lib -lXm -L/usr/lib -lXt -L/usr/lib -lX11 -lm -ll
Undefined Globals:
   _XtGetCallbackList First referenced in //blyger/usr/grass4.1/src/xgrass/libes/LIB/libXgi.a Module Help
ld Error: Not all globals were resolved
*** Exit 1
Stop.
GISGEN failure at STEP: src/xgrass/menu
