Lars,
Are you sure that this was the change you made? I tried your suggestion and
received the following:
sparky% GISGEN.head4.1
GISBASE=/u/cliff/grass4.1
SRC=/u/cliff/grass4/src
CMD=/u/cliff/grass4/src/CMD
HEADER=head4.1
ARCH=
GISGEN Tue Mar 9 12:18:44 EST 1993
GISBASE = /u/cliff/grass4.1
SRC = /u/cliff/grass4/src
CMD = /u/cliff/grass4/src/CMD
HEADER = head4.1
first step: mapdev/digitizers/none
GISGEN failure: mapdev/digitizers/none - not found in lists/GRASS lists/local
sparky%
As far as I remember is this the editing I did in "src/CMD/lists/local".
I had however some apollo specific problems in this directory so I continued
to compile these manually.
But I think your problem might be in src/CMD/next_step/next_step that
still has the old description from your old local file. Try to edit this
file as well so it corresponds to your local file. I would guess that is
says "mapdev/digitizers/none". It should say "src/mapdev/digitizers/none"
Good Luck !!
Lars
Lars Schylberg Email: larss@fmi.kth.se
Dept. of Geodesy and Photogrammetry
Royal Institute of Technology (KTH) Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
