5.0beta4 compile error: d.area
Malcolm Williamson wrote:
> Any thoughts on the following? Compiled under Solaris2.6, gcc, Sun
> Enterprise 5000.
> Thanks,
> /proj/grass4.1/grass5.0beta/src/libes/LIB.sparc-sun-solaris2.6/libgis.a
> -lm
> Undefined first referenced
> symbol in file
> xdrmem_create
> /proj/grass4.1/grass5.0beta/src/libes/LIB.sparc-sun-solaris2.6/libgis.a(opencell.o)
> xdr_float
> /proj/grass4.1/grass5.0beta/src/libes/LIB.sparc-sun-solaris2.6/libgis.a(init_map.o)
> xdr_double
> /proj/grass4.1/grass5.0beta/src/libes/LIB.sparc-sun-solaris2.6/libgis.a(range.o)
> ld: fatal: Symbol referencing errors. No output written to
> /proj/grass4.1/grass5.0/etc/bin/contrib/cmd/d.area
> *** Error code 1
> make: Fatal error: Command failed for target
> `/proj/grass4.1/grass5.0/etc/bin/contrib/cmd/d.area'
this is easy to fix (sorry, we missed it):
Gmakefile of d.area:
Change
LIBES = $(DISPLAYLIB) $(RASTERLIB) $(VECTLIB) $(GISLIB)
to
LIBES = $(DISPLAYLIB) $(RASTERLIB) $(VECTLIB) $(GISLIB) $(XDRLIB)
Then it should compile.
Greetings
