A linux compile problem:
If you're not using the GISGEN program to compile GRASS, I'd strongly recommend
that you do so. That way the libraries that you need will be compiled first.
If you are, then look at the file $GISBASE/src/CMD/lists/GRASS to make sure that
the src/libes/* lines are not commented out (i.e., they should not have a # in
the first column).
Hope this helps.
In message <Pine.SUN.3.95q.970402121033.24692A-100000@verdi> writes:
Hello Grass users-
  I am not well versed in programming or even compiling so please
forgive me is this is a simple problem...
I cannot get anything to compile. I get the following messages: (example)
OBJ.linux/draw_site_label.o: In function `draw_site_label':
OBJ.linux/draw_site_label.o(.text+0x15): undefined reference to
`R_move_abs'
OBJ.linux/draw_site_label.o(.text+0x22): undefined reference to
`R_text_size'
OBJ.linux/draw_site_label.o(.text+0x28): undefined reference to
`R_standard_color'
OBJ.linux/draw_site_label.o(.text+0x103): more undefined references to
`G_define_option' follow
make: *** [/usr/grass/etc/bin/alpha/cmd/d.sites.label] Error 1
I get the same kind of error messages for any grass related compilation.
Any suggestions as to what may be wrong? Thanks in advance,
Jeff Hollenbeck
Dept. of Fishery and Wildlife Science
New Mexico State University
jhollenb@nmsu.edu
Michael Hanratty Phone: (612) 627-4590
St. Anthony Falls Laboratory Fax: (612) 627-4609
Dept. of Civil Engineering
University of Minnesota
Mississippi River @ 3rd Ave. SE
Minneapolis, MN 55414
