about xdigit
Hi, netters:
  I have compiled the xdigit. Everything looks good. But I wonder should it be
invoked under xgrass or grass shell? I have tried to invoked it under grass
shell, however, I encountered a problem that some Motif widget can not be
created. And then the xdigit quit. The error message shows as follow:
X Error of failed request: BadValue (integer parameter out of range for operation)
  Major opcode of failed request: 53 (X_CreatePixmap)
  Value in failed request: 0x0 Serial number of failed request: 413
  Current serial number in output stream: 415
After inspecting the source code, I found that may happen in the subroutine
"make_colors_menu(parent)". Is there anyone could told me what's wrong with
it? and how to fix it?
  Thanx in advance!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
They call me brother wine, but I do'nt like wine so much.
E-mail address: jytsai@nlia5.csie.nctu.edu.tw
