Spam detection software, running on the system "schudra", has
identified this incoming email as possible spam. The original message
has been attached to this so you can view it (if it isn't spam) or label
similar future email. If you have any questions, see
the administrator of that system for details.
Content preview: Hallo, On Fri, Apr 21, 2006 at 05:37:18AM -0400, Yann
Chemin wrote: > Hi all, > a student would like to grow trees
iteratively and compare the outputs > with an aerial photo, while
changing trees parameters from one > iteration to the other. > > We
finally agreed that v.trees3d would do well for a good start at that
job. > We identified that we needed an elevation base map (OK), and a
tree > point location map (OK). > > When i got to check GRASS6.1cvs,
there is no g3.* commands, so i got > confused on how to setup the 3D
study area. I checked in 6.0.2RC4, and > also no sign of g3* commands,
maybe wrong compilation? Or is there > another way? Any tutorial
online? [...]
Content analysis details: (3.3 points, 3.0 required)
pts rule name description
-2.6 BAYES_00 BODY: Bayesian spam probability is 0 to 1%
[score: 0.0000]
0.3 DNS_FROM_RFC_WHOIS RBL: Envelope sender in whois.rfc-ignorant.org
3.1 RCVD_IN_XBL RBL: Received via a relay in Spamhaus XBL
[84.130.77.179 listed in sbl-xbl.spamhaus.org]
2.0 RCVD_IN_SORBS_DUL RBL: SORBS: sent directly from dynamic IP address
[84.130.77.179 listed in dnsbl.sorbs.net]
1.6 DNS_FROM_RFC_POST RBL: Envelope sender in postmaster.rfc-ignorant.org
0.1 RCVD_IN_NJABL_DUL RBL: NJABL: dialup sender did non-local SMTP
[84.130.77.179 listed in combined.njabl.org]
-1.2 AWL AWL: From: address is in the auto white-list
