Add Advertised column to Layers table?
This is an enhancement request for consideration. Would it be possible for you to add a column showing the Advertised setting for each layer in the table on the GeoServer Layers page? Similar to the Enabled? column, this would merely show a check mark or no check mark. The added benefit would be the ability to sort and easily find the layers that are not Advertised, which is currently impossible without looking at all the layers individually. Many thanks for giving this some thought for a future release.
Aloha,
John Maurer
Data System Engineer
Pacific Islands Ocean Observing System (PacIOOS)
University of Hawaii at Manoa
