Addition of two maps
Here is the situation:
  I have two maps that have an overlapping area. I would like to
add the two maps together and use only one map for the overlapping
area. If I use r.mapcalc and preform an addition function it
will add that overlapping area.
How can I avoid this situation?
Thanks for any help.
Kym M. Lenkus
Davidson Laboratory
If I understand you correctly, the following should work:
  newmap = if(map_a,map_a,map_b)
assuming that map_a is the one you want to use in the overlapping area.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
