My apologies for wasted bandwidth. I forgot to mention the initial settings
needed to run the Altek AC31 configuration script that I posted earlier.
S1
0 1
1 dipsw x NOVRAM
2
3
4
5
6
7
8
After setting S1:1 to NOVRAM, reset the controller, and then run the
configuration script. If you are not currently using ArcInfo or PCI, you
can edit those options out of the script.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
