We are using the al30f8_16 digitizer driver in our digcap file.
This setup works for us on a Sun IPC and a Sun Sparc 1+. Good luck!
The only altek digitizer drivers that appear in the digcap file I have
are called altek and altek2. What I am wondering is whether the al30f8_16
is a newer driver that is designed to work with the AC31. Can anyone tell
me whether the al30f8_16 driver is different than the altek driver? If
so, can you tell me how I can get the code for the al30f8_16?
Caroline McDonnell
caroline@magellan.ae.utexas.edu
