Also, I think v.digit was changed in GRASS4.1, and there is a "v.digit2" or
"v.digit.old" code around which is the GRASS4.0 v.digit -- can anyone
shed some light on this? Has ANYONE got an ALTEK AC31 running WELL on
GRASS4.1?
To the best of my knowledge, v.digit2 under GRASS4.1 is identical
to v.digit under GRASS4.0. The only change was that in GRASS4.0
you had to write a driver for each digitizer whereas in GRASS4.1
(with v.digit) all you need is a configuration file.
Martin
Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
Kiel University, Olshausenstr. 40, 24118 Kiel, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma@informatik.uni-kiel.d400.de
