I've noticed that when I use my Altek AC31 digitizer with v.digit2 the
calculated map scale is roughly twice that of the real map scale. For
example, if the real scale is 1:25000, after registering my registration
points it tells me the calculated scale is 1:50000. The support people
at Altek told me to change the resolution setting of the digitizer from
.002 to .001, but then I get error messages telling me the digitizer is
out of sync. Any suggestions?Bill Green
Archaeology Lab
University at Albany
wg1938@cnsunix.albany.edu
Bill,
Why are you using v.digit2? Are you running Grass under Solaris 2.2 or 2.3?
If not, you should use the v.digit program.
Paul Loechl loechl@diego.cecer.army.mil
USA CERL (217)352-6511x7474
