ANNOUNCE: GRASS 4.2.1 (V.18) source code released
Dear GRASS community,
due to the big size of the GRASS 4.2.1 source code package
I have deleted all oldish files left behind from development.
More than 1000 files were taken out (they are saved on my machine
here, if you need them). Also LTPlus and MAPGEN are separated from
the main package into extra packages.
What's new in GRASS 4.2.1 (V.18) source code?
- reduced size: 20MB compressed (V.17 was 45MB) (M.N.)
- r.in.ll corrected, handles properly negative cell values
      now (from J. Bouchard)
- r.in.bin: new "-s" flag and "subst" option for GTOPO30 files (J.B.)
- r.direct: corrected (J.B.)
- added src.alpha/raster/r.in.ppm (M.N.)
- r.hdf - Solaris/Linux compiling problem fixed (M.N.)
- ps.map Segmentation Fault on Solaris 2.6
       fixed in libgis.a: in src421/libes/gis/strip.c (Clifton Wood)
- Removed "chmod 0555 grass42/scripts/*" from script Gmakefiles
   changed partly to "chmod 755" (George Chou)
- r.water.outlet3.0: error message corrected (G.C.)
- r.affinity: comment syntax corrected (G.C.)
- src/libes/gis/G.h: "Too many open files" problem fixed (G.C.)
Thanks to all developers above for their help!
Coming soon:
- GRASS 4.2.1 (V.18) Linux binaries
- TclTKGRASS 2.3 with new nice feature and improved platform independency
Where to find it:
http://www.laum.uni-hannover.de/iln/grass/grass42/
ftp://130.75.72.14/pub/grass421/
- on the mirrors soon :slight_smile:
Also the server structure was (hopefully) improved.
Have fun
     Markus Neteler
Geographisches Institut | Institute of Geography
   Physische Geographie Physical Geography
& Landschaftsoekologie & Landscape Ecology
Universitaet Hannover University of Hannover, Germany
                     neteler@geog.uni-hannover.de
             Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
Dear Markus,
1) I compiled grass_src421v18 without a single error on Redhat 5.1.
2) The src.contrib/CAST/r.colors.paint directory can be safely removed
as it is exactly the same as src.alpha/raster/r.colors.paint.
src.contrib/CAST/r.colors.paint should also be removed from lists/GRASS.
3) There are 2 v.mkgrid in lists/GRASS.
4) There is a little incoherence in
src.alpha/imagery/i.gensig/inter/Gmakefile:
diff Gmakefile.orig Gmakefile
3c3
< $(BIN_MAIN_INTER)/i.gensig: main.o $(LIBES) $(VASKLIB)
$(BIN_ALPHA_INTER)/i.gensig: main.o $(LIBES) $(VASKLIB)
Have a nice day
Jacques
