ANNOUNCE: new GRASS 4.2.1 (V.16)
Dear GRASS Community,
again it is time for an update of the current
GRASS 4.2.1 version...
What is new (major changes):
- as already announced: totally rewritten TclTKGRASS V 2.0! Many, many thanks
       to Jacques Bouchard (bouchard@onera.fr)
         -> new module concept, new module windows etc. etc.
     A Programming_intro is included (you can write your own user
     interface now or modify the existing).
- XGRASS: applied bugfixes from Jacques Bouchard (bouchard@onera.fr)
         -> xdigit working now (but avoid double clicks on filename etc.!)
Added the following scripts/modules:
- added d.rast.rescale: display raster module with automated visualization rescaling
          (many thanks to Dr. Agustin Lobo )
- added i.tasscap: Tasseled cap (Kauth Thomas) transform
- added ps.map.barscale (create a barscale vector layer)
    (thanks to Malcolm D. Williamson, University of Arkansas, Fayetteville AR)
- added r.edge.dig: module to digitize a vector line between two given raster values
          in a raster map (many thanks to Dr. Agustin Lobo )
- added r.out.arctiff: ARC/INFO TIFF export (with .tfw file)
- added r.regression.line: linear regression calculation
- added s.out.gps (many thanks to Johnny Duke at NRCS)
- added v.in.atlas (many thanks to Jill Schueler at NRCS)
- added v.out.atlas
- added v.out.mapinfo (MAPINFO 3.0 compliant)
- added v.distance (thanks to Janne Soimasuo)
          Calculates a distance from a point to nearest line or point in vector layer
- added v.plant (thanks to S.J.D. Cox at AGCRC, CSIRO, Australia)
          Inserts nodes in equidistance into vector map
- added v.cutter.attr: polygon cutter with vector attributes
... and some minor corrections...
Where to get the software/the update package?
  GRASS 4.2.1 main page: http://www.laum.uni-hannover.de/iln/grass/grass42/
  FTP-Server: ftp://hgeo02.geog.uni-hannover.de/pub/grass421/
Many greetings from
   Markus Neteler
   (GRASS Research Group)
      Geographisches Institut | Institute of Geography
- Abteilung Physische Geographie | - Physical Geography
      und Landschaftsoekologie - | and Landscape Ecology -
      Universitaet Hannover | University of Hannover, Germany
                 Email: neteler@geog.uni-hannover.de
             Home Page: Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
I don't whether I'm alone or not, but I'm still trying to get the
v16 version : Since the server does not recognise the ftp "REGET"
command, it's *very* frustating tg get only 43mb and no other
possibility to get the last Mb than to reload the entire archive
(Yes, my connexion is slow and the french reaserch network is
oversaturated... I know, I know).
=> A suggestion for Markus : Is there a possibility to split the
archive in smaller files ? I admit it will be less user-friendly
for loading through a web browser, but with ftp you have just to
use mget instead of get... (I use often "split -b 1420k" to have a
size compatable with 1.44Mb floppies)
BTW, I really appreciate your work for grass/linux. thanks again !
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.25.34.62 Fax: +33 03.88.37.04.97
