> GRASS 5 beta4 is published under GPL:
> http://www.geog.uni-hannover.de/grass/
Yes, I think we are all quite happy (the Baylor team as well!)
BTW, I suppose that there is now a good chance to see Grass included
in Linux distributions (Debian, RedHat, Suse, etc...). Is
anybody thinking about some more "end-user" package (i.e. binaries
+ data + tutorial) ?
Yes, we consider creating "rpm" packages. Perhaps
- one source rpm
- one Linux binary rpm
- one data rpm
But: No idea to create such packages (and no time). any volunteer
to help here?
- one source rpm
- one data rpm
to help here?
You can download the book, Maximum RPM, from the www.rpm.org
website. It's an excellent reference. You can also grab a
few sample .spec files (they specify how to build the rpm)
and tweak them until it works. I'll be glad to help answer
questions, but I'm a little busy to do it myself.
| Eric B. Mitchell mailto:ricdude@toad.net |
On Wed, 27 Oct 1999, Markus Neteler wrote:
- one source rpm
- one data rpm
to help here?
Yes. I will. Gives me a real reason (not just because I like playing) to
work with GRASS and rpm.
I'll start the process this week-end. Weather has got the outside
honey-do list cut short. If I can dodge the inside list I should be fine.
Rod
Roderick A. Anderson
raanders@altoplanos.net Altoplanos Information Systems, Inc.
Voice: 208.765.6149 212 S. 11th Street, Suite 5
FAX: 208.664.5299 Coeur d'Alene, ID 83814
- one source rpm
- one data rpm
to help here?
I'd let the distros sort it out. I know there's a Debian maintainer
working on a 4.2 version *.deb. Each distro might want to muck with
the configuration anyway. However, as a bandwidth impaired user, I'd
appreciate parts of the system being broken up into more manageable
chunks. For instance, grass-core, grass-addins (SWAT, AGNPS, ANSWERS,
etc), grass-docs(html,ps,etc..), grass-sample-data. That 20MB file is a
long download (on a modem) if it succeeds, and many of thoses proggies
don't seem to compile by default anyway.
| Eric G. Miller egm2@jps.net |
| GnuPG public key: http://www.jps.net/egm2/gpg.asc |
