Would converting ARC/INFO coverages into a dlg format be an easy way
of reading files into grass4.0? One question, does the attributes for the
ARC/INFO coverages have to be change into majors and minor codes in the dlg
process and if it does what is the proper way of changing the attributes into
Major and Minor codes.
Thank you;
Daniel H. Rodriguez danR@rsgis3.tamu.edu
Texas A&M University (409) 845-9425
RS/GIS laboratory fax (409) 845-9425
Forest Science Department
College Station Texas, 77843-2135
