arc/info grid-files to grass
From grass-lists-owner@max.cecer.army.mil Wed Mar 17 07:01:43 1993
From: ca4@aixfile1.urz.uni-heidelberg.de (Stefan Jaeger)
Subject: arc/info grid-files to grass
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Date: Wed, 17 Mar 93 13:48:18 CET
X-Mailer: ELM [version 2.3 PL2]
Content-Length: 169
Hello,
I would like to know which is the best way to convert ARC/INFO grid files
to GRASS?
Thanks!
Stefan Jaeger
Dept. of Geography
University of Heidelberg
Germany
This is the way I do it:
r.out.ascii map=yourmap>yourmap.ascii
yourmap.ascii will have grass header information that needs to be changed to the header arc/info requires. So type "help asciigrid" in Arc and it will tell you the header format that arc/info needs. You need to change the grass header to the arcinfo header by editing yourmap.ascii. Then use, asciigrid in arc.
Anantha Prasad
prasad@ghat.inhs.uiuc.edu
