Ralf,
I have seen this problem also and I used digit to remove the offending lin
es.
These lines appear to be bridge lines connecting island polygons which don
't
seem to be removed by ArcInfo clean operations.
Grass is very fussy about such things and considers polygons using a commo
n
line to be invalid.
Ideally it would be nice to fix this problem at the ArcInfo end so that
the bridge lines are removed. I presume they are there in the ungenerate
format for the benefit of some other programs which otherwise have difficu
lty
recognising islands.
Does anyone out there have an ArcInfo solution for this problem?
I am enclosing below a copy of some communication I had with Olga Waupotit
sch
regarding this problem.
Hope this helps. If you find an easy solution I would love to hear about i
t.
start inclusion 1 - my message to Olga
Olga,
Thank very much for your quick reply.
I have tried relabelling but to no avail.I have put the labels
v.support claims not to have matched to areas in a sites file
to see where they lie.
They look to be inside the areas which have open area lines and outside
any islands.
However I have noticed that v.support does not build the topology
correctly if a redundant line is present linking an island to a
surrounding area.
ie. ----------
----->|--| x1| |
| x2 |
In this case the polygon with label x2 is left with open area
lines.ArcInfo must be able to tolerate this but the GRASS logic
can not.Is this a difficult problem to solve or should I try
to find these little redundant vectors ?
end inclusion1
start inclusion2 Olga's reply
The behaver you described I noticed before. I know exactly why it happens
I know exactly how to fix it in v.support.
but Dave Gerdes doesn't want me to fix it. because
he says such polygons are not correct and do not fit the definition of polygon.
The reason it happens is that v.build goes through area edges in clockwise
order always taking the right most edge is the vertex has degree more than 1
when it can't complete the area (i.e. it can't come back to the vertex it start
ed from, it quits.
Instead I beleive it should come baanched out to the right and try with the nex
t edge to the left. This can easily bee implemented as recursion, i.e. at each
vertex we arrive , the function
calls itself for every adjacent edge except the one we came from starting
from the edge thay makes the right most turn.
example
1
o________o
6| |
| 5 |
o___o |2
4| |
o________o
3
v.build goes through edges #1, #2, #3, #4, then it tries to
make the right most turn, and so goes to edge #5, where it comes to dead end
and area fails.
instead it should come back and try edge 6, then it would complete the area.
This is exactly what happens in your case. If you delete the edge connecting bo
undary of
larger area with the island, everything will work fine.
Roight now your large area is not legal by definition, because it
intersects itself. My method would complete your area.
Actually, don't delete this edge, convert it to line edge using v.digit
then it will also work
Olga
end inclusion 2
Subject: ARC/INFO to GRASS conversion
Content-Length: 1804Dear GRASS-users
I will import ARC/INFO vector-files to GRASS. These files contain either area
coverage data or contour lines and have far more than 2000 lines/polygons eac
h.
At this point we try to import a relatively large map containing polygon
features (like a soil map for example). The data were exported using the
UNGENERATE and DISPLAY functions of ARC/INFO resulting in a lines file (.ply)
a label point-file (.pnt) and a label-text file (.txt), according to the
v.in.arc man pages of the users reference manual.Importing the file using v.in.arc worked without any problems. But when
running v.support, only about half of the polygons were not recognized as
areas and could not be recognized. I got an error message likePNT_TO_AREA failed: (3500166.000000 6056598.500000) (Category 4)
Using v.digit, I could see that the problematic polygons seem to be
characterized by a connection to another area both at the start and the end
point of the polygon, that means, the polygons are not closed by itself.I would like to ask if there is a chance to import these ARC/INFO files, eith
er
by choosing another export/import format like DXF or by changing export optio
ns
of ARC/INFO resulting in completely closed polygons. The important point to m
e
is to have a completely labelled vector area map after importing, because thi
s
map has to transformed into raster format.
Thanks in advance
Ralf Kunkel
Phone: +49-2461-3262
Program Group Systems Analysis and Fax: +49-2461-2540
Technological Development (STE) E-mail: r.kunkel@kfa
-juelich.de
Research Center (KFA) Juelich
D-52425 Juelich, Germany
Rod Paterson
Aberfoyle Resources Ltd
Level 31
525 Collins Street
Melbourne Vic., 3000
Phone: 61-3-2706666
Fax: 61-3-2706699
Email: rgp@aberfoyle.oz.au
