I have an .e00 file containing hypsography data. I imported it into GRASS
using m.in.e00, and can display the vector map using d.vect and so on. But
how would I (for example) color-code the contours according to elevation?
I'm new to GRASS, and would appreciate any tips and pointers about
migrating from ArcView to GRASS -- the paradigms seem very different --
and especially any tips on what to do _after_ importing .e00 files into
GRASS. Most info I've found deals with just the import stage.
TIA
--Rick
m.in.e00 creates one category file per attribute in $LOCATION/dig_cats
their name is made with the following rule : <vector_name>.<attribute_name>,
where <vector_name> is the name of your vector file, and <attribute_name>
is the name of an attribute in the Arc/Info coverage.
You have to identify which attribute contains the elevation, then
perform a v.reclass using this file as a base for the rule file.
Michel Wurtz ENGEES - CEREG
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
