ArcInfo to Grass conversion
I'm a new user to GRASS and have done lots of reading, but little
hands-on experimentation so far -- perhaps somebody on grassu-list
can make my weekend more enjoyable/productive with some sage advice.
I need to import 126, 1:20,000 scale forest stand maps (each covers
10km x 10km) into GRASS. All I need in each cell is the unique stand
number (I've renumbered in ARC/INFO so I have unique numbers from 1
to 56,312).
I've been reading about v.in.arc, but ungenerating all those maps and
rebuilding the topology and then rasterizing on the GRASS side seems
a bit much (perhaps those that have done it could assure me that it
is not too bad, or warn me of watch-out-for's).
The other alternative is to use arc/info's POLYGRID command and
output and ASCII file and then use r.in.ascii. Unfortunately, the
file formats aren't quite the same, but I could write code if
required to do the transfer (I'm hoping that somebody has already
done that -- or there is an easier way).
Thanks for any help you could provide.
(P.S. the computer lab is airconditioned, so I'll have a fun weekend
anyway)
Professor Steven Rose, R.P.F. Phone: (705) 324-9144
Sir Sandford Fleming College FAX: (705) 878-9312
PO Box 8000, Lindsay, Internet: srose@flemingc.on.ca
Ontario, CANADA K9V 5E6
