ArcView Shape2GRASS, dig2shape??
At 05:09 PM 12/9/96 -0800, you wrote:
Does anyone know of any work moving ArcView shape files to and from GRASS?
Would a program doing this be useful to anyone other than myself?
What about moving Arc Info coverages to and from GRASS directly without
going thru an intermediate format?
                                           David Mandel
David:
I would be very interested in such a conversion program.
Currently to move from GRASS to Arc (vectors), I export with v.out.arc and
use the Data Automation Kit (DAK) to GENERATE an ArcInfo coverage. ArcView
will then read the ArcInfo files. Finally, a table join is required for the
attribute info. I have never moved data from Arc to GRASS, but it should be
the reverse with UNGEN and v.in.arc.
My copy of the Spatial Analyst (Arc rasters) just arrived, so I need to
experiment with raster GRASS to Arc conversions...
Any suggestions?
-Scott Grover
scottg@horne.com
