Areas in the vector file
       I am trying to label areas in a map. Nowsome areas do not close
|so I get the message unable to define area. I zoomed in and still could
|not see any openings. Is there a way out of this?
Nalneesh Gaur, River Forecast Center, TULSA
Go into v.digit and use the Toolbox command 'o' to display open area lines.
Hopefully this will highlight the polygons which aren't closed.
Marcus
USACERL-TAC
