ascii DXF files
I am trying to import ASCII DXF files into GRASS. I haven't been able to
find where to put them so that GRASS will see them. If I put them in a
"dig" directory, the v.import command sees them as binary and proceeds to
import them until it runs out of memory. I've been through the introduction
to GRASS written by Markus Neteler (not thoroughly through it, but enough so
that I haven't found anything obvious). The manual pages for v.import,
v.in.dxf and v.in.dxf3d haven't been helpful in this regard. The FAQ doesn't
cover this either.
g.list will list binary vector data in the dig directory.
I'm using 4.2.1v18b. I realize 4.2.1v19 has come out, but haven't gone through
the download/compile process yet.
Ben Horner-Johnson
ben@earth.nwu.edu
It has been some time since we have imported DSF so my memory may not be accurate, but I
seem to recall that you simply put them in the current unix directory, or provide the
full pathname on the command line.
Terry Duell, Senior Mobility Engineer
Army Technology & Engineering Agency
Maribyrnong, Victoria, Australia
ph:61-3-93195837 fax:61-3-93195830
