Atlas > GRASS using v.in.dxf (help, irk!)
Hi users, I've been asked to transfer a vector file from Atlas GIS
to GRASS as part of a wholesale shift. Since Atlas can export
its coverages in dxf format it made sense to do that and use
v.in.dxf. When I run v.in.dxf it ticks over the % done but when
it's finished (granted, 98% is the last number I see) I can't find
any dig files in my mapset and when I run v.support it tells me
there are no binary vector files. Am I missing a step somewhere?
The original ATLAS file is just the vectors for a bunch of
polygons with a single attribute attached, and though I don't
know anything of dxf, the file that comes out of ATLAS seems
coherent.
My gracious thanks to anyone in advance...
Peter Briggs
Temporarily at Indiana U. as micromet@rata.geog.indiana.edu
According to our Atlas expert, Atlas GIS exports its dxf files
with blocks and GRASS cannot import blocked dxf files. If
autocad is available, you might try taking your dxf file into
autocad and re-exporting it without blocks.
Unfortunately the ascii route is also not straight forward.
Atlas exports the vector files with easting then northing
in the ascii vector file (should be northing, easting).
Also the header info is missing, and the L or A is some
other sort of label (or so I understand).
There is currently no easy transport route that we know of,
does anyone else know of any?
Nancy Thorwardson (nthorwar@nps.gov) is considering writing
a script to convert the Atlas BNA file to the proper format
for v.in.ascii. If anyone has any existing alternatives,
please let us know!
Susan Stitt
  National Biological Survey susan@gisd.nps.gov
  Information and Technology Services (303) 969-2596
