AW: AW: [Geoserver-devel] Transactions: inserts
Sean Geoghegan wrote:
This is a bug with a version of the sdoapi jar it seems. Try
downloading the latest available sdoapi jar of website or using the
one
in an oracle client install. If you are still having problems, let me
know and I can send you a working one.
I've downloaded the latest version from oracle (I believe I had it
already) and used it, but still, the problem remains the same. I will
try the sdoapi jar from my oracle installation.
Here some information about my installation:
SDO_VERSION: 9.2.0
sdoapi.jar version: 1.0.1
Oracle version: 9.2.0.4.0
The geometry I try to insert is a JTS Point with the following
properties:
- coordinate (202238.869,604600.558,578.672)
- envelope = null
- precisionModel
  - modelType = 2
  - offsetX = 0.0
  - offsetY = 0.0
  - scale = 0.0
- SRID = 0
I've read somewhere on the net that the exception message seems to be
related to problems with connection pooling. Could you send me a version
of sdoapi.jar that works on your machine?
Thanks!
Simon Räss wrote:
>>Ok, I think I've solved this problem. I believe a bug was
introduced
>that
>>broke readCoords when some better handling of coordinate buffers was
>>added. I fixed it in geotools cvs, and updated the jars in
geoserver
>cvs
>>on head and wms-merge.
>Well, the coordinate reading does work now, but I get an exception
from
>the server now:
>"Logisches Handle nicht mehr gültig" means something like "logical
>handle no longer valid"
>org.vfny.geoserver.responses.WfsTransactionException:
>org.vfny.geoserver.responses.WfsTransactionException: Problem
updating
>features
>: org.geotools.data.DataSourceException: Geometry Conversion error
when
>adding features: java.sql.SQLException: Logisches Handle nich
>t mehr gültig cause: oracle.sdoapi.geom.InvalidGeometryException:
>java.sql.SQLException: Logisches Handle nicht mehr gültig
> at
org.vfny.geoserver.responses.TransactionResponse.getSub(TransactionResp
o
>nse.java:212)
> at
org.vfny.geoserver.responses.TransactionResponse.getXmlResponse(Transac
t
>ionResponse.java:105)
> at
>org.vfny.geoserver.servlets.Transaction.doPost(Transaction.java:65)
> at
javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
> at
javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
> at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Applic
a
>tionFilterChain.java:247)
> at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFil
t
>erChain.java:193)
> at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperVal
v
>e.java:256)
> at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.
i
>nvokeNext(StandardPipeline.java:643)
> at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:
4
>80)
> at
>org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
> at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextVal
v
>e.java:191)
> at
i
> at
4
>80)
> at
> at
org.apache.catalina.core.StandardContext.invoke(StandardContext.java:24
1
>7)
> at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.jav
a
>:180)
> at
i
> at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherV
a
>lve.java:171)
> at
i
>nvokeNext(StandardPipeline.java:641)
> at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.jav
a
>:172)
> at
i
> at
4
>80)
> at
> at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve
>java:174)
> at
i
> at
4
>80)
> at
> at
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:193)
> at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:7
8
>1)
> at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process
C
>onnection(Http11Protocol.java:549)
> at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:5
8
>9)
> at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPoo
l
>.java:666)
> at java.lang.Thread.run(Thread.java:534)
>Caused by: org.vfny.geoserver.responses.WfsTransactionException:
Problem
>updating features: org.geotools.data.DataSourceException: Ge
>ometry Conversion error when adding features: java.sql.SQLException:
>Logisches Handle nicht mehr gültig cause: oracle.sdoapi.geom.Inv
>alidGeometryException: java.sql.SQLException: Logisches Handle nicht
>mehr gültig
> at
org.vfny.geoserver.responses.TransactionResponse.doInsert(TransactionRe
s
>ponse.java:252)
> at
o
>nse.java:195)
> ... 33 more
>>Looking at the code, I think the Z coord should work with Oracle.
It
>does
>>not work with Postgis at this time however, as it communicates with
>Well
>>Known Text (or Binary), and the well known stuff is fuzzy on the z
>>coordinate, so JTS just doesn't use it in its WKT reader/writer.
When
>we
>>move to WKB4J it may be easier to support, it looks like it deals
with
>3d
>>stuff a bit better.
>>Chris
>>On Wed, 10 Dec 2003, Simon Räss wrote:
>>>I cannot get inserts working. The features I receive on the server
>side
>>>do not have any attributes. The attributes are somehow dropped
along
>the
>>>xml filter chain. It is (most likely) not a data source related
>problem.
>>>I believe the source of problems lies in TransactionFeatureHandler.
>>>Any ideas what might cause this problem? Otherwise I will start to
>debug
>>>the filter chain step by step and see where the attributes are
>dropped
>>>(the received xml seems to be ok).
>>>An example of what I receive on server side:
>>><?xml version="1.0" encoding="utf-16"?>
>>><wfs:Transaction version="1.0.0" service="WFS"
>>>xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;
>>> <wfs:Insert handle="insert gps point">
>>> <RQS_POINT xmlns="http://www.someserver.com/myns&quot;&gt;
>>> <GEOM>
>>> <Point xmlns="http://www.opengis.net/gml&quot;&gt;
>>> <coord>
>>> <X>202238.869</X>
>>> <Y>604600.558</Y>
>>> <Z>578.672</Z>
>>> </coord>
>>> </Point>
>>> </GEOM>
>>> </RQS_POINT>
>>> </wfs:Insert>
>>></wfs:Transaction>
>>>Another question: are optional attributes supported by the
>>>TransactionFeatureHandler? The above feature type could have some
>more
>>>attributes but they are all optional (in short: the FeatureType has
>a
>>>corresponding attribute for them, but the created feature does
not).
>>>Does this cause any problems? I think I've glimpsed some potential
>>>problem areas, that's why I ask.
>>>Simon
>>>This SF.net email is sponsored by: SF.net Giveback Program.
>>>Does SourceForge.net help you be more productive? Does it
>>>help you create better code? SHARE THE LOVE, and help us help
>>>YOU! Click Here: http://sourceforge.net/donate/
>>>_______________________________________________
>>>Geoserver-devel mailing list
>>>Geoserver-devel@lists.sourceforge.net
>>>https://lists.sourceforge.net/lists/listinfo/geoserver-devel
