AW: [Geoserver-devel] problem: servlet action is not available
... thanks for the answer.
the most confusing thing is that we have two instances of geoserver running on that linux machine with sun and now we get the problems when setting up a third instance!
and on the windows computer i tried the windows-installer and that works. but i need it running on the linux machine.
mark
Von: Chris Holmes [mailto:cholmes@anonymised.com]
Gesendet: Mittwoch, 6. April 2005 11:46
An: Hampe, Mark
Cc: geoserver-devel@lists.sourceforge.net
Betreff: Re: [Geoserver-devel] problem: servlet action is not available
Generally if everything is working except that web admin tool it
indicates that the jre is working fine and the jdk is messing up.
These computers have the full jdk, right? That would definitely do it.
But this error message isn't what I would expect. I find it very odd
that you've tried it on three different machines. Maybe build from
source? Or try the binary install? Just to see if you can get it
working at all. Though perhaps there are problems with sun application
server and struts... that's what the action servlet is for. Do you
need to use the sun one? (yes, we should support it, I'll try to
download and test, but my internet connections are spotty these days).
Sorry to not be of more help, this one's kinda stumping me.
Chris
Quoting "Hampe, Mark" <Mark.Hampe@anonymised.com>:
dear all,
i have problems installing the geoserver in a sun application server
environment.
deploying the war archive is no problem. but when i start the
geoserver =
with http:…:8080/geoserver the welcome.do is called and i get the =
message:
"The requested resource (Servlet action is not available) is not =
available." i've tried to install at three different computers
(linux, =
w2000, xp) but got the same problem everywhere.
has anybody an idea what this can be and can help?
thank you,
mark
SF email is sponsored by - The IT Product Guide
Read honest & candid reviews on hundreds of IT Products from real
users.
Discover which products truly live up to the hype. Start reading now.
http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
hi mark,
we manage to install four instances of geoserver on linux machines with sun java system application server... and having them running...
so i think it's a configuration problem but can you send the complete error message please...
antoine.
mark
An: Hampe, Mark
indicates that the jre is working fine and the jdk is messing up. These computers have the full jdk, right? That would definitely do it.
Chris
dear all,
environment.
geoserver =
message:
(linux, =
thank you,
mark
users.
Read honest & candid reviews on hundreds of IT Products from real users.
http://ads.osdn.com/?ad_ide95&alloc_id396&opÌk
