Dear Miles
I shut the GeoServer down, executed the "chmod -R 777 geoserver" on the entire geoserver directory, started GeoServer again: Same behaviour and error messages as before, nothing improved! Does not seem to have anyting to do with security... ?
Regards, bd
Von: Miles Jordan [mailto:Miles.Jordan@anonymised.com]
Gesendet: Mittwoch, 8. März 2006 00:31
An: Hebel Bernd; geoserver-users@lists.sourceforge.net
Betreff: RE: [Geoserver-users] java.lang.NoClassDefFoundError
... I keep obtaining error messages alike in the attached textfile
(log from a short session calling the demo WMS page
http://syringa.ethz.ch:8080/geoserver/data/demo/popup_map/index.html).
Just an idea... Internal server errors are often caused by incorrect file permissions.
You could try "chmod -R 777 geoserver" (the geoserver directory) and see if that works. Of course you should set more appropriate security later.
Miles Jordan
Applications Developer
The Australian Antarctic Data Centre
___________________________________________________________________________
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the intended recipient, you are notified that use or dissemination of this communication is strictly prohibited by Commonwealth law. If you have received this transmission in error, please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and DELETE the message.
Visit our web site at http://www.aad.gov.au/ ___________________________________________________________________________
