Thanks, this has solved the problem.
Ralf Kunkel
-----Ursprungliche Nachricht-----
Von: Michel Wurtz - ENGEES/CEREG [SMTP:mw@engees.u-strasbg.fr]
Gesendet am: Mittwoch, 17. November 1999 10:47
An: grass@cecer.army.mil
Betreff: Re: GRASS 5.0b4 compile error
"Dr. Ralf Kunkel" wrote:
I am trying to compile GRASS 5.0 beta4 on SuSe Linux 6.2 and got the following error:
make[1]: lex: Command not found
make[1]: *** [lex.c] Error 127
make[1]: Leaving directory `/home/grass5.0beta/src/raster/r.binfer'
1- if you have a command named flex,it is probably the one you need
(gnu version may have a different name than the brand unix version).
You have just to make a link (as root) : ln -s /usr/bin/flex /usr/bin/lex
2- verify that you have installed the yacc/lex package from the suse
distribution. If not do it and verify if you have a command name lex.
If no continue by step 1
Michel Wurtz ENGEES - CEREG
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
