AW: Re: [GRASS-user] v.in.ogr doesn't support Postgres Data Type timestamp
Marcus,
Now it works! Thank you very much.
But during testing I’m running into the next problem of schma support. When I load a layer from schema different to public the schema support works fine. But when I load a layer residing in public schema with “public.
” v.in.ogr is not able to load this layer. GRASS responses with:
“Layer ‘public.
’ is not available”
GRASS 6.2-cvs
Best Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester@bd.so.ch
http://www.agi.so.ch
Von: Markus Neteler [mailto:neteler@fbk.eu]
Gesendet am: Samstag, 24. November 2007 14:44
An: Düster Horst
Cc: grass-user
Betreff: Re: [GRASS-user] v.in.ogr doesn’t support Postgres Data Type
timestamp
Confirmed for 6.2.2. It works in 6.3.x.
The complete test sequence is:
CREATE TABLE test
id serial NOT NULL,
mytime timestamp DEFAULT now(),
text varchar,
wkb_geometry geometry,
CONSTRAINT test_pkey PRIMARY KEY (id)
WITHOUT OIDS;
INSERT INTO test (text, wkb_geometry)
VALUES (‘Name’,geometryFromText(‘POLYGON((600000 200000,650000
200000,650000 250000,600000 250000,600000 200000))’,-1));
this was missing in below example:
select AddGeometryColumn (‘postgis’, ‘test’, ‘geometry’, -1, ‘GEOMETRY’, 2);
import
v.in.ogr dsn=“PG:host=localhost dbname=postgis user=neteler” layer=test
output=test type=boundary,centroid
I have now backported a set of changes:
  • PG driver: PG_TYPE_POSTGIS_GEOM and views backported
  • v.in.ogr: OFTDate, OFTTime and OFTDateTime backported
It now works:
v.db.select test
cat|id|mytime|text
1|1|2007-11-24 13:03:49|Name
To avoid another 6.2.3 release candidate, please download
http://grass.itc.it/grass62/source/snapshot/
→ grass-6.2.cvs_src_snapshot_2007_11_24.tar.gz
and give it a try. I have created the snapshot again to
include these changes.
On Fri, Nov 23, 2007 at 02:40:44PM +0100, Düster Horst wrote:
v.in.ogr v.in.ogr doesn’t support Postgres Data Type timestamp. When you
try to import PostGIS layer with columns of type timestamp v.in.ogr
reports the error p.e.:
table xxx has 4 columns 6 values were supplied
This example error happens when table xxx hat 2 colums of 6 columns with
type timestamp. It seems that v.in.ogr detects the wrong number of
columns.Isn’t is possible to convert timestamp data to character data?
Regards
Horst
Dr. Horst Duester
Kanton Solothurn
Amt fuer Geoinformation
SO!GIS Koordination
Roetistrasse 4
CH-4501 Solothurn
Content-Description: ATT00001
grass-user mailing list
grass-user@lists.osgeo.org
Markus Neteler http://mpa.fbk.eu/markus/
FBK-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
New book: http://www.grassbook.org/
Horst,
could you please try 'ogrinfo' on the layer to see
if plain OGR sees it? From looking at the code I
don't see a reason that a 'public' schema should
fail.
Best,
PS: I still hold 6.2.3 unless this is sorted out.
Düster Horst wrote on 11/26/2007 10:56 AM:
Marcus,
But during testing I'm running into the next problem of schma support.
"public.<table>" v.in.ogr is not able to load this layer. GRASS
responses with:
"Layer 'public.<table>' is not available"
GRASS 6.2-cvs
Best Regards
Horst
Dr. Horst Düster
Kanton Solothurn
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
An: Düster Horst
Cc: grass-user
Betreff: Re: [GRASS-user] v.in.ogr doesn't support Postgres Data Type
timestamp
CREATE TABLE test
id serial NOT NULL,
text varchar,
WITHOUT OIDS;
VALUES ('Name',geometryFromText('POLYGON((600000 200000,650000
200000,650000 250000,600000 250000,600000 200000))',-1));
# this was missing in below example:
select AddGeometryColumn ('postgis', 'test', 'geometry', -1,
'GEOMETRY', 2);
# import
v.in.ogr dsn="PG:host=localhost dbname=postgis user=neteler" layer=test \
- PG driver: PG_TYPE_POSTGIS_GEOM and views backported
- v.in.ogr: OFTDate, OFTTime and OFTDateTime backported
It now works:
v.db.select test
cat|id|mytime|text
-> grass-6.2.cvs_src_snapshot_2007_11_24.tar.gz
> v.in.ogr v.in.ogr doesn't support Postgres Data Type timestamp. When you
> columns.Isn't is possible to convert timestamp data to character data?
> Regards
> Horst
> Dr. Horst Duester
> Kanton Solothurn
> SO!GIS Koordination
> Roetistrasse 4
> CH-4501 Solothurn
