awk, site files, etc
Chris Skelly recently wrote:
Yes, but the point I think the others were making was that if there
are two ways to do something lets go the route best for the user, not
the programmer. Having said that...if I had to make a decision on
where
to put GRASS programmer time at this point it would _not_ be on
"desk top" GUIs. It would 98% on analysis functionality. If I want a
neato-jiffy point click and gee look at the diolog box I will buy
a PC commercial product, eg MAPINFO. GRASS is not IMHO designed to
impress computerphobic managers, its for researchers and people who
know enough about what they want that they might want to tinker with
the code.
Unfortunately, the original issue-- the one that started this
discussion-- wasn't about fancy GUI's or other bells and whistles. It
was about whether to expand the sites file format to include elevation
and possibly other ancillary data. I think that this indeed add
analysis functionality, but I agree with Bill Hargrove in the sense
that users should understand the inner workings of the file
manipulations their analyses are performing, and *nothing* fosters more
knowledge of grease-monkey file manipulation than using the built-in
Unix file processing tools to do the job.
Sometimes though, the temptation to cobble something together with
shell scripts should be avoided. It's a great way to prove a concept
or work out a method, but in the long run GRASS functionality won't be
extended with subdirectories full of shell scripts. As GRASS's
functionality is extended with new tools it is reasonable to expect its
underlying file structures to change as well so they can exploit the
possibilities inherent in those tools.
One final thought on the site file format discussion: why not add a tag
to each field, i.e.
north=83401.65|east=4578.9|elevation=1638.0|label=burial_mound etc.?
Then sites programs could parse each line in the file and extract
*whatever* data they need. Users building site lists could put any and
all data they want into the site description.
Michael Camann camann@dial.pick.uga.edu
Department of Entomology camann@phoenix.cs.uga.edu
University of Georgia (706) 542-1388
Athens, GA 30602 (706) 542-2276
Michael makes the suggestion that:
to each field, i.e.
ok, but does this improve functionality given that two sites files
83401.65|4578.9|1638.0 and 83401.65|4578.9|burial_mound
accomplish the same thing? If you have to add tags to all columns
how much more complicated will you need to make the file header (he
says thinking aloud)? Actually, if you had two extra lines in the
header part of the sites file:
tags=on
north|east|elevation|site_feature
and if tags=off or the ommission of a tags=on/off line indicated
that the sites file was to be treated as per the norm we might have
the best of both worlds...
chris
I disagree. The only thing that I see that might speak against this style
of functional extension and adaptation is performance. If it is found that
only compiled-language coding will give adequate performance for a
particular job, then so be it. Where that is not the case, though, or
where the trade-off between development overhead and performance favors
the shell-script route, then that route can, should and is taken.
As GRASS's
I think a better case might be made for creating and sticking with simple
data interfaces between highly flexible tools, rather than mucking around
with changing those interfaces too often.
-- Mark
Mark P. Line Phone: +1-206-733-6040
Open Pathways Fax: +1-206-733-6040
P.O. Box F Email: markline@henson.cc.wwu.edu
Bellingham, WA 98227-0296
