Jim,
Forwarded message:
From owner-GRASSLIST@baylor.edu Mon Jan 17 09:53 CST 2000
Message-Id: <1046411238831E79@webmail>
Date: Mon, 17 Jan 2000 10:45:37 -0500
Sender: owner-GRASSLIST@baylor.edu
Precedence: bulk
To: GRASSLIST <GRASSLIST@baylor.edu>
Subject: Beta 5 and its lockfile
MIME-version: 1.0
Content-transfer-encoding: 7bit
X-Sender: jbrowne <jbrowne@liu.edu>
X-Mailer: WebMail (Hydra) SMTP v3.60
X-WebMail-UserID: jbrowne
X-EXP32-SerialNo: 00002866
X-Listprocessor-Version: 7.2 -- ListProcessor by CREN
Content-Type: text/plain; charset="ISO-8859-1"
Content-Length: 916What did I do wrong?
I've had GRASS5beta4 running since October, I was hesitant to touch it but
yesterday I uninstalled it and installed beta5. When I tried to run it and
got:GIS.sh line 23: 1308 Segmentation Fault $ETC/lock $lockfile$$
Unable to properly access /home/nydir/.gislock5The directory is right and there should be no permission problems. I even
tried it from root, same thing. As a kludge, I commented out the exit;; line
in the script. GRASS then started, but exited too fast for me to read any
messages.I looked at the Beta4 source, and it seems that returning 0 flags a lock
and 1 is O.K.. The script seems to expect the opposite. I'm going to download
and check the new source.If this was a bug, and a fix was posted, my apologies. With both the forum
and the mail archive down, I couldn't check.Thanks
Jim
FYI I got the same thing, did the same things, etc. It seems that a bit
of housekeeping is needed in upgrading versions - not so bad, if one knows
about it, but annoying otherwise.
Adios,
Chris
C.S. Cornuelle
School of Mathematics/MCIM, University of Minnesota
206 Church St. SE, Minneapolis, MN 55455
(612) 626-8930v, (612) 624-2333f, bob at math.umn.edu
Ferventer Vestite
