Agus....
I'm writing a program to input uncompressed
cell files to Splus. I have no problems to
import files coded with 1,2 or 4 bytes per
pixel provided the map is all positive,
but I get weird numbers importing negative
values (regardless of # of bytes). I'm sure
my program works as it is supossed to because
I have double checked importing grass cell maps
with negative values to other programs (i.e.,
Spyglass for Mac) and get the same weird
results. Are negative values coded in
some particular way in grass? Why?
I've found that a file created as:
r.mapcalc "del.me = -1"
r.compress -u del.meis coded in 4 bytes per pixel. Why?
Thanks
Agus
Firstly, doing anything with grass' internal representation of data is
probably a bad idea. Who knows what its going to look like in the next
release. Get the grass programmer's manual and have a look at the
section regarding reading and writing rasters. There are a bunch of
function calls that provide an applications program interface to the
underlying data structure, whatever that may be. I suspect that if you
use the API you will probably get sensible negative numbers.
As for the weird negatives, how about this for a theory: Some machines
use "sign extension" when promoting shorter ints to longer ints (i.e.
sign bit gets replicated all the way to the MSB of the word), and some
just fill out the rest with zeroes and set the MSB accordingly. I
suspect both these models are at work in your case, the conflict giving
you weird negatives but sane positives.
David Houlder Phone: +61 6 249 4613
Geography Department (In Aust.: (06) 249 4613)
The Australian National University Fax: +61 6 249 3770
