This message bounced around for two days to max (not moon....)
its almost moot w/ message from Scott but anyway....
I'm not sure we shouldn't go private here but since I've already
confused everybody .. well the correction should be posted.I'n the earlier posting I typed p.ppm when i MEANT p.map
oops... other than that what I said is correct. I think.Are there any ppm hackers out there who can chime in
More stuff below the following.....
> Fred,
> Now I am even more confused. Perhaps I should have memtioned in
> my note that I was following your instructions in GRASSCLIPPINGS
> 6(1):16 . After issuing p.select painter=ppm, I ran p.map with
> scale=6in. This produced the paint.ppm file, as expected. Then,
> on my system I entered:
> ppmtopgm paint.ppm | pgmtops | lpr -Papple
> which produced the b&w map, but without the legend or bottom frame
> line. In other words, I didn't use p.ppm. My understanding was
> that p.map used with ppmtogrm would create my b&w map with the legend.
> Isn't this the case? In fact I seem to recall that when I ran p.map
> I received a message telling me that the map then the colortable were
> being written to paint.ppm.I may be offbase here but I don't remember getting a colortable using
yes-- p.map with the painter selected as ppmas to sizing... there was a neat post a while back which illustrates
one way... this uses xpr to print a xwd formatted file ..from Chris Murphy at Oregon State
pnmtoxwd paint.ppm | xpx -device xxxx -height 17 -width 11 -density 180 -landscape | lpr whatever
> Thanks for your reply
W. Fredrick Limp, Director FAX: (501) 575-3846
CAST, Center for Advanced Spatial Technologies TEL: (501) 575-6159
12 Ozark Hall, University of Arkansas
Fayetteville AR 72701 fred@kirk.uark.edu
