Daniel H. Rdoriguez writes:
What is the best way of buffering a polygon or line vector file.
We were able to buffer a site (point) file with s.poly. Is there a command which will buffer a line or a polygon ?
GRASS analysis is performed 99% in the raster realm. Use v.to.rast to convert
lines and polygons ("areas") to raster format, then use r.buffer to do your
buffering. r.poly converts back to vector format, with the -l flag initiating
a smoothing option. Obviously resolution is a very important issue in these
conversions - make sure that yours is appropriate for you data and you
application.
Malcolm D. Williamson - Technical Assistant E-mail: malcolm@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-5736
Ozark Rm. 214 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
