this bug's URL: http://intevation.de/rt/webrt?serial_num=2179
Bernhard Reiter wrote:
> > As far as I can tell all the compile problems with r.terraflow are
> > because of the #include lines.
> > With gcc3.2 and 3.3 all #include <X.h> should be replaced with #include
> > <X>.
> > Also, the header strstream.h is deprecated, and should be replaced with
> > sstream.I'll take it this exclusively holds for C++?
Yes.
--- Headers Follow ---
From glynn.clements@virgin.net Wed Oct 22 13:23:27 2003
Return-Path: <glynn.clements@virgin.net>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 4A56F13ABE
for <grass-bugs@lists.intevation.de>; Wed, 22 Oct 2003 13:23:27 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP
id 16DCE36DD0; Wed, 22 Oct 2003 13:23:27 +0200 (CEST)
Received: from mta4-svc.business.ntl.com (mta4-svc.business.ntl.com [62.253.164.44])
id C7B5A36DCE; Wed, 22 Oct 2003 13:23:25 +0200 (CEST)
Received: from cerise.nosuchdomain.co.uk ([62.252.68.51])
by mta4-svc.business.ntl.com
(InterMail vM.4.01.03.37 201-229-121-137-20020806) with ESMTP
id <20031022112319.SMHG21751.mta4-svc.business.ntl.com@cerise.nosuchdomain.co.uk>;
Wed, 22 Oct 2003 12:23:19 +0100
Received: (from glynn@localhost)
by cerise.nosuchdomain.co.uk (8.11.6/8.11.6) id h9MBLVP01045;
Wed, 22 Oct 2003 12:21:31 +0100
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Message-ID: <16278.26683.150352.856190@cerise.nosuchdomain.co.uk>
Date: Wed, 22 Oct 2003 12:21:31 +0100
To: Bernhard Reiter <bernhard@intevation.de>
Cc: Request Tracker <grass-bugs@intevation.de>, grass5@grass.itc.it
Subject: Re: [GRASS5] C and C++ compiler changes?
In-Reply-To: <20031022083600.GD28324@intevation.de>
References: <20031020211825.78C6F13B9A@lists.intevation.de>
<20031021151649.A8008@polynum.org>
<3F956B71.8070800@bowdoin.edu>
<20031021200532.A9158@polynum.org>
X-Mailer: VM 7.07 under 21.4 (patch 14) "Reasonable Discussion" XEmacs Lucid
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=5.0 tests=BAYES_00
X-Spam-Level:
