[bug #5490] (grass) Re: [GRASS-dev] v.digit: Could not set Tcl system encoding fixed (bug #4110)
this bug's URL: http://intevation.de/rt/webrt?serial_num=5490
--8XkdMeO807
Content-Type: text/plain; charset=us-ascii
Content-Description: message body and .signature
Content-Transfer-Encoding: 7bit
Markus Neteler wrote:
> I'm pretty sure that the problem is that lib/form/form.c doesn't call
> Tcl_Main(), so the library path doesn't get set, so Tcl can't find its
> .enc files.
> Realistically, if you are trying to use Tcl/Tk and your program
> *doesn't* look very much like tkAppInit.c, all bets are off.
> Rather than trying to process the data from the form library in C,
> form.c should just register the commands then do the rest in Tcl.
Since I know nothing about tcl, I'll leave that to the experts. AFAIK
form.c was
originally written by Radim.
The attached patch appears to work, insofar as v.digit appears to work
as before, minus the encoding errors. OTOH, I know next to nothing
about v.digit (or the vector stuff in general), so it would probably
be a good idea for it to be tested by someone who is familiar with
v.digit.
Essentially, the form utility (lib/form/form.c) has been rewritten as
a typical "extended wish", with the communication with the form
library being performed in Tcl.
--8XkdMeO807
Content-Description: lib/form patch
Content-Disposition: inline;
  filename="form.diff"
Content-Transfer-Encoding: base64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--8XkdMeO807--
--- Headers Follow ---
From glynn@gclements.plus.com Sat Feb 10 15:59:12 2007
Return-Path: <glynn@gclements.plus.com>
Delivered-To: grass-bugs@lists.intevation.de
Received: from kolab.intevation.de (salmakis.hq.intevation.de [192.168.11.9])
  by lists.intevation.de (Postfix) with ESMTP id 147611005CB
  for <grass-bugs@lists.intevation.de>; Sat, 10 Feb 2007 15:59:12 +0100 (CET)
Received: from localhost (localhost.localdomain [127.0.0.1])
  by kolab.intevation.de (Postfix) with ESMTP id EF60B108ECA
  for <grass-bugs@lists.intevation.de>; Sat, 10 Feb 2007 15:59:11 +0100 (CET)
  by kolab.intevation.de (Postfix) with ESMTP id B3293109152
Received: from cerise.gclements.plus.com (82-71-30-52.dsl.in-addr.zen.co.uk [82.71.30.52])
  by kolab.intevation.de (Postfix) with ESMTP id 3780E108ECA
  for <grass-bugs@intevation.de>; Sat, 10 Feb 2007 15:59:09 +0100 (CET)
Received: from cerise.gclements.plus.com (localhost [127.0.0.1])
  by cerise.gclements.plus.com (8.13.7/8.13.7) with ESMTP id l1AEx4Qt012042;
  Sat, 10 Feb 2007 14:59:04 GMT
Received: (from glynn@localhost)
  by cerise.gclements.plus.com (8.13.7/8.13.7/Submit) id l1AEx40l012039;
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary="8XkdMeO807"
Message-ID: <17869.56760.385929.175604@cerise.gclements.plus.com>
Date: Sat, 10 Feb 2007 14:59:04 +0000
To: Markus Neteler <neteler@itc.it>
Cc: Request Tracker <grass-bugs@intevation.de>,
  grass developers list <grass-dev@grass.itc.it>
Subject: Re: [GRASS-dev] v.digit: Could not set Tcl system encoding fixed
  (bug #4110)
In-Reply-To: <45CC2C73.5030206@itc.it>
References: <45C9995E.7010700@itc.it>
  <45C9F585.30406@o2.pl>
  <45CAD4F8.5050400@itc.it>
  <17867.3200.384675.355130@cerise.gclements.plus.com>
  <45CB36F6.1070906@itc.it>
  <17867.42607.267308.193576@cerise.gclements.plus.com>
X-Mailer: VM 7.07 under 21.4 (patch 20) "Double Solitaire" XEmacs Lucid
X-Virus-Scanned: by amavisd-new at intevation.de
X-Spam-Status: No, hits=-5 tagged_above=-999 required=3 tests=[BAYES_00=-5]
X-Spam-Level:
