this bug's URL: http://intevation.de/rt/webrt?serial_num=898
(cc RT)
On Fri, Jan 18, 2002 at 11:09:36AM -0500, Helena Mitasova wrote:
I used r.slope.aspect for curvatures quite a bit and did not have a problem
(except that it does not write the custom color table as the rst programs do
which is annoying)
- I will test it too, but I want to ask whether you had a mask set, because I
might not have used it with a mask.
Helena
...no, I didn't:
GRASS:~ >g.list rast |grep MASK
GRASS:~ >
It can be even replicated with the Spearfish data.
(If you are computing it to visualize the waves along contours, I am covering
that in the applications, so do not worry about that right now)Neteler wrote:
> Hi,
> today we realized a nice crash of r.slope.aspect:
> r.slope.aspect elev pc=z.rsa.pcurf
> percent complete: Segmentation fault (core dumped)
> If you try the spearfish data:
> r.slope.aspect elevation.dem pc=z.rsa.pcurf
> The debugger tells us that there is something strange in
> libes/gis/null_data.c
> Program received signal SIGSEGV, Segmentation fault.
> 0x8056635 in G_set_f_null_value (fcellVals=0x0, numVals=1) at null_val.c:295
> /ssi0/ssi/neteler/cvsgrass/src/libes/gis/null_val.c:295:9157:beg:0x8056635
> (gdb)
> Unfortunately this doesn't tell me anything? Probably the NULL
> implemenation is weird in null_val.c?
> To our surprise the aspect/slope calculation runs well.
> It would be nice to have that fixed...
> Thanks,
> Markus
--- Headers Follow ---
From neteler@itc.it Fri Jan 18 18:29:30 2002
Return-Path: <neteler@itc.it>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 4DAD6139CC
for <grass-bugs@lists.intevation.de>; Fri, 18 Jan 2002 18:29:30 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
by mail.intevation.de (Postfix) with ESMTP id 18A761B6BB
for <grass-bugs@intevation.de>; Fri, 18 Jan 2002 18:29:29 +0100 (CET)
Received: from artemide.itc.it (artemide [10.0.10.10])
by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g0IHTRr01652
for <grass-bugs@intevation.de>; Fri, 18 Jan 2002 18:29:27 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
by artemide.itc.it (8.11.3/8.11.3) with ESMTP id g0IHTPx15223;
Fri, 18 Jan 2002 18:29:26 +0100 (MET)
Received: (from neteler@localhost)
by thuille.itc.it. (8.11.6/8.11.2) id g0IHTPO23330;
Fri, 18 Jan 2002 18:29:25 +0100
Date: Fri, 18 Jan 2002 18:29:25 +0100
To: grass5@grass.itc.it
Cc: grass-bugs@intevation.de
Subject: Re: [GRASS5] r.slope.aspect crash - libes/gis/null_data.c
Message-ID: <20020118182925.Y483@itc.it>
Mail-Followup-To: grass5@grass.itc.it, grass-bugs@intevation.de
References: <20020118135702.T483@itc.it> <3C4848C0.63A0FE21@unity.ncsu.edu>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5i
In-Reply-To: <3C4848C0.63A0FE21@unity.ncsu.edu>; from hmitaso@unity.ncsu.edu on Fri, Jan 18, 2002 at 11:09:36AM -0500
X-Spam-Status: No, hits=0 required=5 tests=
