[bug #900] (grass) Re: [GRASS5] r.slope.aspect crash - libes/gis/null_data.c
this bug's URL: http://intevation.de/rt/webrt?serial_num=900
when you give it both curvatures it runs, when you give it only pc curvature
it crashes. So this looks as another unfinished enhancement and genuine bug. I do
not have time to look at
it untill Feb.1, but somebody else may be able to fix it (and add the colortable
from rst too).
Helena
GRASS:~ > r.slope.aspect bh02dec01.t800 slope=slp.test aspect=asp.test pcur=pc.test
percent complete: Segmentation fault (core dumped)
tcur=tc.test
percent complete: 100%
CREATING SUPPORT FILES
ELEVATION PRODUCTS for mapset [helena] in [jockey-state]
min computed aspect 0.0019 max computed aspect 359.9997
Color table for [asp.test] set to aspect
ASPECT [asp.test] COMPLETE
min computed slope 0.0000 max computed slope 9.9895
SLOPE [slp.test] COMPLETE
PROFILE CURVE [pc.test] COMPLETE
TANGENTIAL CURVE [tc.test] COMPLETE
Neteler wrote:
(cc RT)
On Fri, Jan 18, 2002 at 11:09:36AM -0500, Helena Mitasova wrote:
> Markus
> I used r.slope.aspect for curvatures quite a bit and did not have a problem
> (except that it does not write the custom color table as the rst programs do
> which is annoying)
> - I will test it too, but I want to ask whether you had a mask set, because I
> might not have used it with a mask.
> Helena
...no, I didn't:
GRASS:~ >g.list rast |grep MASK
GRASS:~ >
It can be even replicated with the Spearfish data.
> (If you are computing it to visualize the waves along contours, I am covering
> that in the applications, so do not worry about that right now)
> Neteler wrote:
> > Hi,
> > today we realized a nice crash of r.slope.aspect:
> > r.slope.aspect elev pc=z.rsa.pcurf
> > If you try the spearfish data:
> > r.slope.aspect elevation.dem pc=z.rsa.pcurf
> > The debugger tells us that there is something strange in
> > Program received signal SIGSEGV, Segmentation fault.
> > 0x8056635 in G_set_f_null_value (fcellVals=0x0, numVals=1) at null_val.c:295
> > /ssi0/ssi/neteler/cvsgrass/src/libes/gis/null_val.c:295:9157:beg:0x8056635
> > (gdb)
> > Unfortunately this doesn't tell me anything? Probably the NULL
> > implemenation is weird in null_val.c?
> > To our surprise the aspect/slope calculation runs well.
> > It would be nice to have that fixed...
> > Thanks,
> > Markus
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
--- Headers Follow ---
From hmitaso@unity.ncsu.edu Fri Jan 18 21:29:49 2002
Return-Path: <hmitaso@unity.ncsu.edu>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id C34DF139CC
  for <grass-bugs@lists.intevation.de>; Fri, 18 Jan 2002 21:29:49 +0100 (CET)
Received: from Mail6.nc.rr.com (fe6.southeast.rr.com [24.93.67.53])
  by mail.intevation.de (Postfix) with ESMTP id 4517D1B6BB
  for <grass-bugs@intevation.de>; Fri, 18 Jan 2002 21:29:48 +0100 (CET)
Received: from unity.ncsu.edu ([66.26.232.232]) by Mail6.nc.rr.com with Microsoft SMTPSVC(5.5.1877.687.68);
   Fri, 18 Jan 2002 15:29:40 -0500
Sender: helena@intevation.de
Message-ID: <3C4879A7.C8BA46A7@unity.ncsu.edu>
Date: Fri, 18 Jan 2002 13:38:15 -0600
Organization: NCSU
X-Mailer: Mozilla 4.73 [en] (X11; U; Linux 2.2.16-3 i686)
X-Accept-Language: en
MIME-Version: 1.0
To: Markus Neteler <neteler@itc.it>
Cc: grass5@grass.itc.it, grass-bugs@intevation.de
Subject: Re: [GRASS5] r.slope.aspect crash - libes/gis/null_data.c
References: <20020118135702.T483@itc.it> <3C4848C0.63A0FE21@unity.ncsu.edu> <20020118182925.Y483@itc.it>
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
X-Spam-Status: No, hits=0 required=5 tests=
