I ran into a minor glitch when trying to use the SUN binaries off of the new
Young Minds cdrom of GRASS4.1.2 (the one that OGF is distributing). In the
script "setup.sh", line 35 reads
if test "$x" != "" -o "$x" = "n" -o "$x" = "N"
when it should read
if test "$x" = "n" -o "$x" = "N"
Otherwise it'll keep on spitting you back to the start of the script.
Other than that, no problems (I haven't checked the same script in the other
binary releases.).
Thanks for persevering on the cdrom, David and Pamela!
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
