Yes, you can label the polygon in v.digit, v.support it, then use v.to.rast
in=name out=name2. Ensure that the resolution is what you want it to be before
using v.to.rast. You can use r.mask then on the raster file.
I have a polygon described in a vector file, and want to build a mask from it
so that I can mask out cells in raster files that are outside of the polygon.
Does anyone have ideas on this?
Rick Thompson- Research Assistant E-mail: rick@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-5736
Ozark Hall Rm. 12 Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
