Bulk Label Lines from the command line
Does anybody know of a way to bulk label all of the "lines" in a file from the
command line? My files contain "areas" or "lines", exclusively, and all of the
"areas" or "lines" in each file have the same attribute.
I am currently using the "Bulk Remaining Lines" command in v.digit, but I see
plenty of room for error on my part. I would prefer a non-interactive command
so that I can automate the labelling process.
I labeled my "area" files using the v.alabel command in a shell script. All of
the "areas" were labeled with unique attributes within minutes. I would like to
do the same for my "line" files.
Somebody... please help.
Virginia Jackson
Engineering Research Associates
jackson@era.com
