bulk label lines
Darrell writes:
        if ( 0 < Vect_read_next_line(&Map,Points) )
          X = Points->x[1] + 0.5*(Points->x[0] - Points->x[1]);
          Y = Points->y[1] + 0.5*(Points->y[0] - Points->y[1]);
        else
where X and Y are the location of the label points. Is this
valid? It worked on my UTM test case ...
The points in the line are not neccessarily in order from west to east,
if that's what you're asking.
I'm not familiar with the program you're working on, but in general to
make this work in lat-long, you should use:
east = G_adjust_easting (Points->x[i], &wind);
or something like that.
bill
