C++ in GRASS
Hi GRASS programmers,
Does anybody know how to incorporate C++ code into GRASS programs?
We tried to use g++ instead of gcc and moved our source to a .cpp
filename ... only realizing that compilation failed with a bunch
of error messages. So this doesn't seem to be a promising way.
Thanks for your help.
Olaf
The C++ compilation should not work because C++ is a lot less forgiving
about the headers of each function definition.
C++ can call C functions quite happily, so it's just a matter of the
headers not compiling in. When I did this, I just modified the header
files as I needed them.
Angus Carr.
Olaf
