Call for help!
Hallo everybody!
I am a mathematician from Vienna, working on the field of scattered data=20
approximation. For the application of some methods from geostatistics=20
(external drift kriging) to real world data from hydrology, I have to=20
incooperate information from a digital elevation model, and found GRASS=20
in our computer network which might be just the right tool for me.
As I am a complete beginner in this field, I would really appreciate=20
all help or hints to the following problem:
I=ADve got the elevation model as xyz-data on a grid of 50m, and for each=
=20
point I would like to determine the following two quantities:
1) The area which drains into this point, i.e. all points uphill from=20
which water can flow down to the point under consideration, and
2) The angle between the surface and the horizontal plane. I think this=20
is called the slope or so.
The motivation for this is the following idea: I am trying to estimate=20
the moisture of the soil, and thought that it might be related to the=20
topography. The bigger the area from which a point recieves water the=20
wetter the soil. On the other hand, if the slope is very steep, then=20
the water will accumulate somewhere downhill, decreasing the water content=
=20
of the ground.
Maybe the two questions are completely trivial, but I would really find any=
=20
hint extreamly helpfull.
Thanks a lot,
                  =09=09Mitch Rauth
  NUHAG (Numerical Harmonic Analysis Group)
  Michael Rauth e-mail:
  University of Vienna rauth@tyche.mat.univie.ac=
.at
  Department of Mathematics anonymous ftp: 131.130.22=
.36
  Strudlhofgasse 4
  A-1090 VIENNA phone: ++43-1-4088311/4
  AUSTRIA fax: ++43-1-4088311/5
** =20
