Cannot get ltplus to run
Bob Atnip writes:
I'm having trouble with ltplus. The files "ltpgo & ltplus" were located in my
/home/atterbury/grass/4.1/ltp/bin directory. When I tried to type ltpgo I got the error message "No such command '/usr/local/ltp/bin/ltplus'". I copied the
"ltpgo & ltplus" files to /usr/local/ltp/bin directory, then when I typed
ltpgo I got the message:
               setting internal variables: paths.h
                         Welcome to Line Trace Plus.
                         Version 2.22 Dabritz/Jonson/Martin,
Loading lookup tables. Done.
Loading configuration variables.
error in initialize: get_config failed to execute.
Line Trace Plus terminating.
In order for ltplus to execute correctly the following directories need to
be at the same level as the bin containing ltplus, ltpgo:
bin dictionary ibm map_lists
config digitizers incl maps
cursor_keys digmenus macros menus
dictionaries export make_links pens
These directories are found under src.related/LTPLUS after compilation. I believe
the problem you are encountering has to do with the code locating the dir config.
James A. Farley Technical Director, CAST/NCRI-SW
            12 Ozark Hall, Univ. of Arkansas
jim@cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
