Changed the subject so it's separated from the LIDAR discussion.
Markus N.: the latest svn has fixed the location wizard problem. It now works.
I'm still getting errors when I try to run v.in.lidar. It complains that:
python: can't open file
'/home/daniel/grass_src/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gui_modules/menuform.py':
[Errno 2] No such file or directory
Is there anything I can do?
Daniel
On Fri, Nov 25, 2011 at 1:00 PM, Markus Neteler <neteler@osgeo.org> wrote:
On Fri, Nov 25, 2011 at 1:05 PM, Daniel Victoria
<daniel.victoria@gmail.com> wrote:
Grass compilation went fine but unfortunatelly I still can't test it
because I'm having some other problems. Location Wizard is not opening
I have fixed this in SVN, the files weren't installed after the layout
change (r49356).
Not really. The wxGUI in trunk is currently largely broken due to
reorganization, will hopefully be fixed soon...
Markus M
Daniel
change (r49356).
2011/11/25 Daniel Victoria <daniel.victoria@gmail.com>:
should be fixed in r49359.
Yes, recently wxGUI modules have been reorganized [1] to more GUI
packages. I would expect that a lot of features will be broken. Please
report every bug you will find. I hope to stabilize wxGUI within few
days. Thanks for helping with that!
