Can't run d.mon
Hello Malcom
I am running a video mode with more than 256 colors. I used to have
color problems whenever I opened GRASS monitors and e.g. Netscape. There
would notbe enough colors available. I got the advice to upgrade to 2 MB
of DRAM, which I now have and I am running at depth 16. Is it not possible
to run more than 256 colors? Should I change some settings?? Thanks for
such a prompt response!! Curious whether I should not have gone for
the upgrade.
Luc
On Mon, 21 Oct 1996, Luc Boerboom wrote:
Hello Malcom
the upgrade.
Luc
Hi, Luc
Nope, you can't run more than 256 colors with the standard GRASS xdriver.
However, some kind soul (I can't recall who!) wrote a version of xdriver
that will display a GRASS 256-color monitor window on a 24-bit display. I
can arrange for you to ftp the source code from me if you'd like; drop me
a note directly (if anyone else needs this, let me know too). I've used
it quite successfully on both Sun 24-bit displays, and 24-bit xterm
emulation software (Hummingbird's eXceedNT, Intergraph's eXalt).
Hopefully your upgrade won't be wasted! (Just don't expect any benefits
for GRASS :frowning: )
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
As Malcom said, there is an XDRIVER24 available. There is a binary
available for Linux on Moon, and I run it here occasionally.
It isn't entirely perfect, but it works. Which is what I wanted.
To get XFree86 to run at 8bpp (256 colors, pseudocolor, palette color,
whatever else you want to call it) you need to specify the -8bpp in the
command line to X, which is found in the xinit script in
/usr/X11R6/lib/X11/xinit (I think.) Another approach is to modify
/etc/XF86Config to use 8bpp by default by ( I seem to recall) putting the
8bpp section before the 16bpp section at the bottom of the file.
I played around to get all this to work, but it is all in the man pages
(somewhere) for Linux. I wish you luck finding it. I didn't enjoy it, but
my system now does what I want it to.
Angus.
Hello Malcom
the upgrade.
Luc
